Prouty's Hayabusa Turbo Locost
Postby Proutyc » Wed Feb 22, 2017 7:42 am
Thought this is the best way to show the updates on what appears to be a car with good bones.
All the lights etc will be modernised with LED and maybe Halo on the driving lamps
The car currently has an injected 4AGE with a few modifications.
At the moment just piecing together the replacement engine and a few composite parts. My engine is designing a cradle to sit the engine into
The engine thats going in
Here the custom dash we are fitting
Proutyc
Re: Prouty's Hayabusa Turbo Locost
Postby Proutyc » Fri Mar 03, 2017 6:21 pm
Just about to start building up the engine. This engine has lower compression pistons than my race engine as this will spend most of its time on 98 octane, while the race car is on e85
Carrillo rods all sized and inspected.
Pistons have arrived. Will be setting the rings over the weekend
Gauges are modified and the new lamada, oil pressure, oil temp gauges that will be installed into the carbon dash
I have also flashed the hayabusa ecu so that it can control the turbo fueling, removed the bike sensors and also remove all the limiters
Head just came back from having porting work, after market spring and kibblewhite stainless valves
Proutyc
Postby Proutyc » Fri Mar 03, 2017 6:49 pm
Also just serviced the shocks.
These are called dynamic dssv and are very adjustable. These shocks are used by red bull f1, and a number of lmp1 cars.
I was lucky enough to get these from the winding down of the gt3 panoz program.
Proutyc
Postby Proutyc » Wed Mar 08, 2017 6:37 pm
More engine parts arrived today. Almost ready to go start the turbo build.
Upgraded engine studs to take the planned 250-300hp
All new engine bearing so will the engine will be as good as new throughout.
Proutyc
Postby Proutyc » Thu Mar 09, 2017 10:19 am
Taken me a little while but finally had my mate in the USA track me down another one of these beautys
Turbo comes from the current spec indycar. These are light, weighing in just over 5kg as pictured. I use this same turbo on my race car (same engine to) and we are seeing 350hp at the wheels at 11psi. Full boost is at 4.5k rpm, they are light and efficent.
Cant wait to see how this looks on the side of the 7
Proutyc
Postby Proutyc » Mon Mar 13, 2017 7:52 am
Feeling very lucky.
Last night was online about to order the output drive, a electric reverse kit and pricing up paddles all from the UK when I thought hang on lets check what a car starter motor is going to add to the bill. What I found at that time was this little beauty online so snapped it up. This should make things alot simpler
Proutyc
Postby Proutyc » Mon Mar 13, 2017 8:16 am
Thankfully almost at the end of just spending money and not installing anything.
Drive flange all made for the ford driveshaft
Billet alloy paddles ready for install
Proutyc
Postby Proutyc » Mon Mar 13, 2017 12:05 pm
Billet sump has arrived to so now we are pretty close to being able to finish the motor
Proutyc
Postby Proutyc » Wed May 03, 2017 11:19 am
Quick Update
Hoping to finally get the car in the garage next week and start pulling the old 4AGE engine and transmission out Ready for the new powerplant.
Have made a template for the new carbon dash
Have purchased a Deutsch connector kit so I can now start to mate the existing loom into the Hayabusa loom we are using
Proutyc
Postby Proutyc » Tue May 16, 2017 9:35 pm
Started the horrible job of planning the electric due to the engine swap. How do they have some much wire in a bike
Will start the horrible job of cutting it up next week
Proutyc
Next
Return to Build Diaries
Users browsing this forum: No registered users and 2 guests
cron
