Hi all,
Yes the Zetec is a left hand exit, common engine size is 1.8 and 2.0 lt, cast iron block and produces 107 kws in standard Ford tune. Popular in the U.K in kit cars with a huge amount of go fast bits available from the well known engine tuners, Raceline, Cosworth ,Minister etc.
The 7 engine of choice. The Duratec is a newer Ford/Mazda engine available in I think 1.3,1.6,1.8,2.0,and 2.3 lt 4 cylinder and 2.5 and 3.0 lt V6 in a huge range of Ford/Mazda cars Focus, Fiesta, Mondeo, Ranger, Mazda 2,3 and 6 etc. The block and head are cast Aluminum and therefore lighter than the Zetec. Has a cast brace supporting the the crank bearings giving a very strong and rigid bottom end. Very popular here in Australia with Birkin, Prb, Westfield, Caterham etc all fitting Duractecs as standard in there cars.The 2.0 lt produces (148hp)109 kws in standard Ford tune.Exhaust exits on the right(drivers) side.
I have a Duratec(2.0lt) fitted in my Birkin with standard Ford factory ECU,injection and airbox fitted and obviously extractors fitted. I have a Dreamscience flash tuner/code reader for the ECU with the mildest tune increasing the hp to 170 hp. This is a very mild tune at present and I know that standard Ford Focus with the Duratec fitted in the U.K producing 175/180hp after reflashing the ECU and still running the factory injection and exhaust with cat still fitted. It will be interesting to see what horsepower I can get running all the standard Ford gear and just tuning the ECU? Again a huge amount of go fast bits available, probably more than the zetec.
Check out the engine build on the 2nd link, if only it was so easy, but who needs a manual to build an engine now!
Cheers
Maurice
http://images.google.com.au/images?hl=e ... CCcQsAQwAwhttp://video.google.com.au/videosearch? ... CC8QqwQwCA
