Cutting perspex / acrylic
Anything else
Postby bzrse7en » Sat Jun 10, 2017 1:15 pm
have just had some headlight covers moulded for a lotus 23 in acrylic at great expence. They have a compound curve and required the company to make a press to form the parts. They are a specialist acrylic forming company.
A quick and careful trim with a metal cutting bandsaw and supporting the part, one has cracked - almost shattered. Temp in the shed about 7 degrees.
Is it likely it is too cold, or that the parts wern't annealed / cooled properly so had internal stress, or that I am a rough ba$ted?
I have played with this material many times and I know it is brittle. Just wasn't expecting this much.
thanks
Patrick
Re: Cutting perspex / acrylic
Postby SR Components » Sat Jun 10, 2017 3:53 pm
The guys I used cut headlights etc with a router at very high speed.
SR Components
Postby 7dreamer » Sat Jun 10, 2017 10:02 pm
Was going to suggest a router too may be with a larger bit to try reduce heat build up
7dreamer
Postby bzrse7en » Sat Jun 10, 2017 10:20 pm
The item is so fragile, small and curved, I doubt I can route it easily. Was going to try a dremel with cut off wheel. I reckon there are stresses from moulding still in it thou.
Postby davew » Sat Jun 10, 2017 11:17 pm
Try a hot wire, or soldering gun with a thin blade. The blade will leave a larger ridge than the wire and may need to be sanded down a little more the a wire. A friend made a large "C" frame hot wire, which allow you to trim a M/C racing fairing bubble in on pass and in less the 10 minutes. Also use a soldering iron and melt in the mounting holes. Dave W
davew
Postby bzrse7en » Sun Jun 11, 2017 10:01 am
davew wrote:Try a hot wire, or soldering gun with a thin blade. The blade will leave a larger ridge than the wire and may need to be sanded down a little more the a wire. A friend made a large "C" frame hot wire, which allow you to trim a M/C racing fairing bubble in on pass and in less the 10 minutes. Also use a soldering iron and melt in the mounting holes. Dave W
I like that idea, pretty sure i have the gear somewhere.
Postby nz_climber » Sun Jun 11, 2017 3:17 pm
Belt sander!
Postby davew » Sun Jun 11, 2017 11:28 pm
The hot wire leaves a very nice edge and requires very little sanding. I used a die grinder and fine grit sanding drum. Dave W
davew
Return to General Tech
