johns Chevron MX5
Re: johns Chevron MX5
Postby 7ish » Mon Sep 14, 2015 4:59 pm
Use a ball pein hammer (round end!) And dent each hole down a few mm so the bog has somewhere to sit. Shame you can't shift them...holes add lightness.
Postby JohnL » Mon Sep 14, 2015 6:12 pm
thought about using a counter sink drill to taper the holes, but the hammer will do a better job I think, cheers
Postby JohnL » Fri Sep 18, 2015 1:06 pm
so I found an aluminum cover just doing nothing and thought it looked a lot like a fuel tank. Measure it and the car space up and I can make a 30l tank out of this that will sit behind the MX5 subframe and give me a boot. It will have one baffle and an internal swirl pot. just have to find a piece of 3mm Al for the top and back.
Postby JohnL » Fri Jan 15, 2016 7:07 pm
be warned, photo heavy post!
well tank is in and a sump added underneath. then as its a long holiday with some long service leave added in I thought I could do some finishing touches
the tunnel was just too big, so I cut it out and made a better one.
then I thought a new fresh skin would look good
and then go rid of the dsuz bonnet latches I fitted, no some simple stainless clips
then I made a bimini top for it
Postby JohnL » Mon May 09, 2016 8:39 am
more changes have been happening
hard cover for the "boot"
cut some alloy to the shape and screwed it in
then covered it with Vinyl
then got to run to hobbies at once, had a bike race to do that required driving through some sweet road used in the Targa, so had to make the most of the opportunity
Postby flewy » Tue May 10, 2016 3:42 pm
I while ago I was reading a wikipedia page about the history of NZ number plates (bored at work), one thing I wondered was why when I brought Cossie it had MX200 as the number plate, and 3 of the dudes other cars had different make ups of MX200. Turns out (from wikipedia), that the number plates MX1 thru to MX999 were trial number plates checking out the new white plates with black writing. Anyhow you have one of those plates it seems.
https://en.wikipedia.org/wiki/Vehicle_r ... ew_Zealand
Something random for you all today...... :D
Postby JohnL » Tue May 10, 2016 6:47 pm
thats cool, I wished it was mx160 cos now I have to put an 1800 in it :D
Postby JohnL » Tue Oct 25, 2016 1:26 pm
a few more updates
got a CNC router at work now, so in the spirit of learning new things I made a new dash
Postby JohnL » Tue Oct 24, 2017 11:32 am
well its never finished is it. got the singer out and re did the upholstery, gone is the carpet seats and in with the stitched vinyl, all practice for the roof build
Previous
Return to Members Rides
Users browsing this forum: No registered users and 3 guests
