Chris's 12sec Seven
Re: Chris's 12sec Seven
Postby KiwiBirkin » Thu Sep 10, 2009 4:43 pm
Cycle guards are going to really finish of your car Chris, as for towing it back and forth to the race track just drive it there and back :) also are you keen to come blatting with us as I see your in Christchurch.
Stephen
Stephen
1998 Birkin S3 Blue/Aluminum Toyota 20v Blacktop
Postby 12sec » Fri Sep 11, 2009 2:54 am
I am keen but my car is currently off the road as reg is on hold and just tidying up a few things guards will come one day
12sec
Postby Bigred » Mon Feb 01, 2010 7:16 pm
Hi Chris
Have you got your car back on the road yet?
Have you experienced any negatives with having a turboed engine in your 7 vs NA?
I'm guessing anything with that power to weight requires respect.
I've got a Mitsi 2L turbo engine which was earmarked for my build. Not sure if it'll fit in the Tui but might do a test fit over winter.
Much like the Mazda it's quite a tall engine.
I'm not sure if it's the way to go now or not but I've got the engine sitting in the garage so it'd be a shame not to!
Cheers
Cliff
Bigred
Postby nz_climber » Mon Feb 01, 2010 7:48 pm
I think the main problem with turbo vs na in a seven is the heat in the engine bay, getting rid of it can be a problem, and also finding somewhere to fit a large enough intercoolers
Anyway not to hijack this thread, but keen on seeing any progress Chris has made?
Beams 3sge Powered Mcgregor 7 http://aarons7.wordpress.com/
Postby 12sec » Fri Feb 19, 2010 12:09 pm
so as for some lap times had a cruzy 1:40 round ruapuna with trafic and yes you have to think very hard if doing a turbo as engine bays are small and heat is a huge factor i'm currently designing a new car and looking to take my street car back to around 180hp at the wheels for relyability but we will see
12sec
Postby kaspa » Fri Mar 12, 2010 7:21 pm
guys, yes your right putting a turbo in a clubby poses a massive heat dispersal problem, but all is not lost there is a very easy and simple solution that works
took a bit of trial and error, but 12lbs boost on a 13b in 40 degree heat, and even in heavy traffic not a sign of getting hot.
cheers Kaspa
John
Hp,= how fast you hit the wall
Torque,= how far the wall moves when you hit it
kaspa
Previous
Return to Members Rides
Users browsing this forum: No registered users and 1 guest
