7ish new new build...
Post by 7ish » Wed Mar 06, 2019 3:46 pm
I have taken over the build of Clank's ZZR1400 turbo clubbie.. he's done great work but seems to have lost motivation ( and he wanted a Porsche...)!!
DMC
Re: 7ish new new build...
Post by DMC » Mon Apr 22, 2019 10:14 pm
Keen to see how this progresses. Any updates?
Post by 7ish » Tue Apr 23, 2019 11:21 am
Slow going due to other commitments, but have sorted the water to air intercooler pump and radiator and added an oil cooler to the front end. Hopefully some better progress over winter.
Bruce Wilson
Post by Bruce Wilson » Fri May 17, 2019 8:13 pm
Simple just own both...that was my solution. Looking forward to seeing the car I am at MMS for two weeks.
Bruce
2017 McGregor MACHsr7
http://kitcarnz.com/
Post by 7ish » Thu May 30, 2019 6:18 pm
Starting again on the wiring... bike loom was too long and looked untidy..
A CBS wiring module from Bruce to tidy up the boring bits:
Post by 7ish » Thu May 30, 2019 6:19 pm
Front cooling issues sorted...
Post by 7ish » Thu Jun 06, 2019 9:48 am
Attacked the wiring... about half done now
Post by 7ish » Thu Apr 23, 2020 10:25 am
Some progress made finally on the new new project... Gave up on the original ecu system... Clank was planning on using the stock ecu with a piggyback power commander, a piggyback ignition controller and a separate boost controller. After some consideration, I decided that would be way too hard to tune, so biffed the lot and wired in a Link monsoon ecu. Also added the necessary bits to run E85 race fuel as it will be kinder on the engine under boost. Flex fuel sensor, 1000cc injectors, bigger fuel pump.
As the turbo is quite low mounted, I needed a scavenge pump to return the oil to the sump. Unfortunately the one I bought only lasted about 15 minutes. New (better) one on order from Italy.
The motor starts and runs, will be down to the dyno as soon as everyone is back to work.
The car has a design approval and has had two build inspections from Don Hoff, who has now retired. I have no paperwork for his inspections, so hoping either the guy he sold his business to has some copies, or is willing to let me continue towards cert.
Bruce Wilson
Post by Bruce Wilson » Wed Apr 29, 2020 11:25 am
EVAN...looking great and nice to see that the wiring is being well sorted. Seems I am locked in Japan and my car is so close to being finished and not sure when I can make it back to Christchurch to finally have it on the road. I am sure you will be on the track well before me...roll on 2021!
Bruce
Post by 7ish » Tue May 26, 2020 10:05 am
Some progress. Had issues with the G4+ ecu ... didn't like the high compression, low inertia motor so was giving trigger errors on start. Link stepped in and gave me one of their new G4X ecu's... works perfectly.
Off to the dyno 5th of June.
