Post by Wanganui7 » Sat Feb 02, 2019 12:14 pm
This morning worked on the stainless grill . Started off trying to use 5 mm wire but found it very hard to bend. Seamed to work harden. Changed to 4 mm which I bent around a dollie welded to the bench. Tig welded with the 7shield brought earlier off ebay . About two hours work to do. Still to do mounting brackets also fit the led daytime lights in behind. Am thinking about fitting some woven stainless steel mesh in behind to. Had previously brought a silver and black enamelled super 7 badge from UK but it didn't stand out very well so ordered two black and yellow ones instead. A big improvement and they just happened to be on half price special.
Post by Wanganui7 » Sun Feb 17, 2019 3:03 pm
Today started working on the rear panel. Cut some alloy oversize and had a friendly local panel beater roll the corners for free. Always find car guys a friendly bunch , down to earth and willing to help. Clamped to the car , marked and recut closer to the finished size. Fitted to car again and started to roll the top edge over using piece of wood as a dollie and hammer. The tube your rolling over is only 19mm and bounces a bit while hammering so I will take off car , fit a solid 19 mm sold rod inside rolls for final hammering and finishing. With this done just needs some right angle bends on the press brake.
Post by Wanganui7 » Sat Mar 02, 2019 11:36 am
Continuing working on the rear panel. Used 1.2 mm alloy and was by far the hardest panel so far, taking about two weeks of my spare time to form. Using press brake at work for right angle bends and hand beating top edges. Final fitting of lights to do and will make a bracket to hold spare tyre.
Post by Wanganui7 » Sun Mar 24, 2019 1:37 pm
Sprayed a few coats of paint on the second hand rear guards to bring them up like new, just needing a cut and polish to finish. Bolted on the car and will fit stainless steel stone guards later. Also wired up the front led indicators and daytime lights. I have used a gas soldering iron for years without problem . But learnt today to make sure it's out before refilling. Who knew you could get such a big explosion from so little gas! The smell of burnt arm hair filled the garage. Luckily no lasting damage.
Post by Wanganui7 » Sat Apr 27, 2019 8:49 pm
Been slow progress over the past two weeks having to spend time fixing another car. Just finishing smaller jobs, a bit of painting and tidying wiring. Today made a start on the windscreen making the side stays and next will decide on the height of the screen and make the alloy channel frame.
Post by Wanganui7 » Sat May 04, 2019 11:23 am
Knocked up a bracket to mount the spare wheel in my lunch hours at work. Bit ugly but after powder coating orange and the wheel on, won't notice it. My old old car never had a spare and not a flat tyre over 11 years, but I'm mostly using this one for touring so thought I'd better have a spare.
Post by Wanganui7 » Fri May 17, 2019 5:52 pm
Post by Wanganui7 » Sun Jun 16, 2019 2:24 pm
Been working on the mounts for the front guards. Still the front mounting point to finish. Also doing the scuttle cover. . Welding a recess for the bonnet. Normally you would get a plumber with an edge setting tool to roll it. But I was just short on plate and didn't want to buy a whole new sheet to get the job done. A little sanding and should come up ok.
Post by Wanganui7 » Wed Jun 26, 2019 6:26 pm
Finished the scuttle cover and is now ready for powder coating. So started on the bonnet. Using 1.6 alloy bent around a tube clamped to the bench. Worked well just needing some tweaking before folding bottom edges. Bit hard to get the motivation now with the garage dropping to 0 degrees at night.
