Mid engine design (Rear engine cars?)
steveb
Post by steveb » Tue Dec 13, 2016 1:22 pm
other than bzrse7en's 23, are there any other rear engine cars being built. i came across the "midlana" with rear honda power, there is an abundance of fwd engine /trans combos out there.
I saw at my local "pick it" place some small honda and mazda's with a front strut assy similar in design to ford sierra, PCD 100ish mm.
I am thinking this as rwd gearboxes like the t-50 are getting older and harder to find, and break with torque
any thoughts?
Re: Rear engine cars?
Post by bzrse7en » Tue Dec 13, 2016 8:40 pm
With an east - west FWD box, it is rear engined and can be a bit twitchy I believe unless you get things just right, but Nor - south configuration is mid engined and will likely have same weight distribution as a front engined 7 @ around 45% - 55%.
How about a Subaru and transaxle?
The thing is though, many think about a midi, there is logic to the design, but don't want to risk building an uncontrollable or over complicated monster when they know tried and true works.
steveb
Post by steveb » Wed Dec 14, 2016 7:14 am
yes there is the balance thing, it wouldn't be so bad for the left hand drive market. toyota mr2, mrs , lotus elise etc seem to make it work.
DMC
Post by DMC » Thu Dec 15, 2016 9:56 am
This one got my attention. Doesn't look too bad and seems to go quite well. Plus it is AWD, turbo and runs on a BBQ bottle of LPG. Interesting how he has turned the transfer case around to point forward....
http://www.locostusa.com/forums/viewtop ... hilit=riot
steveb
Post by steveb » Thu Dec 15, 2016 5:53 pm
nice,
i wonder what other 4wd's this would be possible with? be a bit on the heavy side and getting away from being a simple bare bones car,
less is more. Still quite impressive, good create thinking too!
steveb
Post by steveb » Wed Jan 04, 2017 10:01 am
I should of titled this "mid engined" as opposed to rear engined kit cars.
my error. "changing this now"
steveb
