Weber 45 air filter replacement
scottie84
Post by scottie84 » Tue Feb 07, 2017 5:43 pm
Hey guys and gals, can anyone point me in the right direction to get a couple of new air filters for my Weber 45 Sidies on the 4AGE? It appears I have some oddball rectangular filters on there at the moment as all I have been able to find that come close are oval type. Dims 166 x 110 x 43. Or should I scrap the current set up for an improved design?
feckn7
Re: Weber 45 air filter replacement
Post by feckn7 » Tue Feb 07, 2017 6:25 pm
Have a look at Uni Filters
http://www.uniflow.com.au/contents/en-us/d136.html
I had some sock filters and then went to a Uni filter - much better
Some of the models have a blank base plate that you can cut to suit
David
Post by 7ish » Wed Feb 08, 2017 7:30 am
You would notice a performance improvement if you could run some short trumpets inside the filter... dyno testing on a motor of mine really smoothed out the power curve.
I used a pipercross foam filter on a single back plate... Palmside has them in NZ, cheaper from demon tweeks.
scottie84
Post by scottie84 » Wed Feb 08, 2017 8:04 am
Thanks heaps guys, I've been doing a bit of digging and looking in to trumpets so I think I'll go that way.
Super7Alfa
Post by Super7Alfa » Sat Feb 11, 2017 11:10 pm
K & Ns are pretty similar and were standard fitment by Caterham.
http://nzairfilter.co.nz/search.php?mode=search&page=1
