Road to Kaikoura
Re: Road to Kaikoura
Post by 7ish » Thu Mar 02, 2017 8:01 pm
Drove the inland scenic route from Glentunnel through Oxford, then Ashley gorge road through to Loburn. Great road, hardly any traffic, very pleasant, but it is a test of a compliant suspension in places......
Post by Birdman 7 » Thu Mar 02, 2017 9:10 pm
I did the same trip on Saturday Evan and managed to dodge the worst of the road imperfections. For a change I did not hit the ground anywhere, but usually strike at least once. It certainly does give the suspension a work out, and there is one particularly bad hollow just out of Oxford on the way to Ashley Gorge that requires a careful entry and exit.
Post by heavyseven » Fri Mar 03, 2017 8:53 am
nz_climber wrote:Easy to rewire the headlight relay to turn off when ignition is off.
There are some theoretical occasions where you may want your headlights on without the ignition, so I'm happy just putting a beeper across it.
I'm not running a headlight relay either...
