Useful Links to Car Related Nonsense
Post by Rookie » Fri Oct 16, 2009 10:08 am
Hey Guys, I thought I should make a page of good links to car related stuff that I have found over the years, You guys are welcome to add to it, and perhaps it could be stickyed? in no particular order:
Wheels, tyres and suspension:
http://www.rims-n-tires.com/rt_specs.jsp Tyre and wheel converter
http://www.hraefn.net/projects/spring_rates.php Spring rate converter
General engine technical info:
http://www.pumaracing.co.uk/index.htm A lot of good info on older ford stuff, and quite a bit on engine tuning in general
http://www.billzilla.org/carindex.htm Bill is the man, In it for the love of it etc, his page is full of good ideas and good tech advise/data mostly Toyota
http://home.clear.net.nz/pages/phil.bradshaw/Index.htm Another good Toyota page, plenty of helpful info here
Seeing as I have one, Ford Crossflow:
http://www.cortina-mk1classifieds.com/f ... .php?t=958 Pretty basic info but helpful
http://freespace.virgin.net/tommy.sandh ... ifications Oodles of info on crossflows and fords
http://www.geocities.com/marty7_nz/dats ... index.html putting a datsun crank into a crossflow
http://www.burtonpower.com/Default.aspx Not just crossflows but all ford stuff
Carburetors:
http://www.geocities.com/motorcity/9526 ... tml?200929 Weber DCOEs
http://forums.turbobricks.com/showthread.php?t=16697 Half way down, For Dellorto DHLAs same as above, but with the different part classifications that Dellorto use
http://www.viva-lancia.com/fulvia/qanda ... llorto.php For correct balancing procedure of side drafts
Toyota gearboxes:
http://users.tpg.com.au/users/loats/tec ... boxes.html Toyota W series gearboxes
http://www.geocities.com/MotorCity/Pit/ ... boxes.html A whole bunch of info on Toyota gearboxes
Drysump:
http://www.toymods.net/forums/showthrea ... light=sump Billzilla explains how to make you own drysump setup.... Cheaply!
Car Rego Info:
http://www.carjam.co.nz/ if you are buying a car it is worth while to put it trough here
Hope this helps
Dave
Qwiksylva
Re: Useful Links to Car Related Nonsense
Post by Qwiksylva » Sun May 02, 2010 10:20 pm
Lots of ideas for dfferent dash designs, courtesy of Locost builders UK.
http://www.locostbuilders.co.uk/viewthr ... ?tid=64223
Post by Rookie » Wed Jun 16, 2010 7:34 pm
Another really good site for all Toyota part numbers is:
http://www.toyodiy.com/
Lynx88
Post by Lynx88 » Thu Jul 01, 2010 1:17 pm
Good power/torque unit converter. I mostly use it when I'm dreaming / browsing!
http://www.mr2ownersclub.com/converter.htm
82 KP60 Starlet 4AGTE
"Driving fast on the track does not scare me. What scares me is when I drive on the highway I get passed by some idiot who thinks he is Fangio." - Juan Manuel Fangio
Post by heavyseven » Thu Jul 01, 2010 3:28 pm
You can use google search to convert any units. just type in something like "180 foot pounds to kilogram centimeters" and see the result. It's quite neat how feature rich, yet un-cluttered the basic google applications are.
actually, the above example does not seem to work, but many forms of measurement do...
type37
Post by type37 » Sat Jul 02, 2011 10:19 am
An excellent site for 7 type cars in general. There's a specially useful tool if you are contemplating using a Ford engine-there are 2 drop-down boxes side by side. You enter the model of 1 engine in 1 box and another engine in the other. It then gives you a comparison of the 2 engines-weight, height, length, approx power output, mods and general comments about tuning potential etc. Unfortunately it is heavily Ford biased. Think from memory the only non Ford engine is the Toyota 4AGE. Pity someone hasn't done the same for all the engines commonly used in Clubman type cars.
Spyder
Post by Spyder » Sat Jul 02, 2011 11:52 am
Lynx88 wrote:Good power/torque unit converter. I mostly use it when I'm dreaming / browsing!
Just add a third to go from hp to kW and imperial torques to metric torques. Not 100% accurate, but close enough given that the original numbers are likely to be interneted anyway ;) And of course 1/4 off to go the other way.
type37
Post by type37 » Sat Jul 02, 2011 3:19 pm
Might help if I put the web address in for the Westfield site Duhhhh. http://westfield-world.com/
Post by Rookie » Tue Jul 12, 2011 1:17 pm
General
Post by General » Fri Jun 14, 2013 1:01 am
Taken From latest Kit Car Mag. All from adds
Rally design large range from fasteners to performance stuff Two sites WWW.rallydesign.co.uk
and www kitcarmarketplace.co.uk
Similar to above www.demon-tweeks.co.uk
Smith instruments and cables www.speedycables.com
Rubber seals and trims for kit cars www.sealsplusdirect.co.uk
Prima motorsport belts safety mostly comp stuff www.primamotorsport.com
Electrical www.autosparks.co.uk
Europa Huge amount of stuff online catalogue www.europaspares.com
Car Builder Solutions have 365 page catalogue www.cbsonline.co.uk
Springs and shocks www.dampertech.co.uk
Springs and shocks www.protechshocks.co.uk
Instruments and digital dash's www.etbinstruments.com
Hope this is usefull to builders and maintainence.
