Fuel tank material
Fuel tank material
Post by 7ish » Mon Feb 16, 2015 12:03 pm
Can anyone tell me what the min thickness of ali is for a fuel tank these days?? Thanks.
Re: Fuel tank material
Post by JohnL » Mon Feb 16, 2015 12:28 pm
from LVVTA manual
Technical requirements:
10.1 Fuel tank construction
10.1.1
A new custom or one-off fuel tank may be fitted to a low volume
vehicle as an alternative to a fuel tank from a mass-produced
vehicle, provided that the tank is constructed from fuel-resistant
and corrosion-resistant materials, with a minimum thickness of:
(a)
in the case of aluminium, 1.6 mm (16-gauge); or
(b)
in the case of stainless steel, 1.0 mm (20-gauge); or
(c)
in the case of ‘electro-galv’ mild steel, 1.2 mm (18-gauge).
Post by 7ish » Mon Feb 16, 2015 2:44 pm
Thanks.... I found something similar on line, but I had the feeling that it was increased in a recent change.
I'll go ahead and make it in 2mm, then lie when asked what thickness if necessary!
Post by Rookie » Mon Feb 16, 2015 3:23 pm
Watch out they might make you drill a witness hole in the bottom of it...
Post by bzrse7en » Mon Feb 16, 2015 4:43 pm
7ish wrote:Thanks.... I found something similar on line, but I had the feeling that it was increased in a recent change.
Make it in 3mm, 2mm will ripple when welding.
Mark told me this after I had made mine from 2mm, he was right.
