roll bar padding?
roll bar padding?
Post by JohnL » Tue Mar 24, 2015 9:37 am
so what are the options .....and where do I find it?
certifier wants main hoop padded with HD foam
ta John
Re: roll bar padding?
Post by Talkiet » Tue Mar 24, 2015 10:11 am
Not sure if it's the right stuff but worth looking at the Warehouse at their hollow pool noodles!
Post by JohnL » Tue Mar 24, 2015 12:01 pm
found this in the LVVTA
2.4(9) A low volume vehicle fitted with a roll-bar or
a roll-cage, must have:
(a) a head restraint fitted to provide protection for each
occupant where a roll-bar or roll-cage section exists immediately
behind a seat, positioned between the occupant seating posit
ion and the roll-bar or roll-cage section; and
(b)
no unprotected hard or sharp bracketry including a roll-bar or
roll-cage mount, seatbelt mount, or fastener positioned where it
would be likely to be contacted by an occupant in the event of
an impact or roll-over; and
(c)
all sections of a roll-bar or a roll-cage positioned adjacent to any
A-Zone must be covered in a high density energy absorbing material which:
(i)
meets SFI specification 45.1 or another equivalent
motor-sporting specification; and
(ii)
is not less than 15 mm in thickness in the area facing the
occupant cell.
Post by nz_climber » Tue Mar 24, 2015 8:04 pm
Speedway shops usually have heaps of this stuff
techtoys
Post by techtoys » Wed Mar 25, 2015 8:14 am
Racetech in Lower Hutt has rollcage padding. They've got an online shop. They also list it on TradeMe.
http://racetech.co.nz/shop/racing-produ ... ge-padding
