Long Bolts
DMC
Long Bolts
Post by DMC » Thu Sep 17, 2015 10:13 pm
Hi,
I may have made a slight error... I got approval to use 7/16 rod ends on my suspension arms and have the arms already built and crack tested etc.
The problem is I now need a couple of 7/16 (or I guess 11mm) grade 8 bolts that are about 235mm long, or the equivalent in stainless.
I have had no luck at any of the local suppliers at all so far, can anyone suggest where I might find some?
Thanks
Doug
Re: Long Bolts
Post by nz_climber » Fri Sep 18, 2015 4:54 pm
How come they are so long? Can you give us a photo, maybe you could modify the design to use 2 shorter bolts?
