Use this forum to openly discuss anything you would like regarding the project cars in the build diary's
* Edit post
* Delete post
* Report this post
* Information
* Reply with quote
Forum Rules. EVERYONE MUST READ BEFORE VIEWING OR POSTING
Postby KiwiBirkin » Tue Nov 10, 2009 6:10 pm
Poject Discussion Forum Rules
This is a new section of where you guys can discuss other users cars. There are just a few rules that need to be followed for this forum to stay nice, clean and easy to use:
1. ONE thread per car. Search the forum for an existing thread before starting your own, things stay tidy that way.
2. Try and stay on topic if you can.
3. Thread titles must be in this format: Username's and the car project
I have created this section so it keeps the build diarys clean and allows the builder of the car to keep us updated a bit like a BLOG so please use this section to disscuss the builders cars and we should see a much easier forum to navigate.
Post by Wanganui7 » Sat Jan 12, 2019 9:01 pm
Thanks, motors a good pysical size. Allows easy access all around it. Would hate to fit a V8 in there like some do.
Birdman 7
Post by Birdman 7 » Tue Feb 05, 2019 8:52 pm
Lookin' good.
Post by Wanganui7 » Tue Feb 05, 2019 9:31 pm
Thanks, builds taken close to three years now with a break for overseas holiday. Getting close now though.:)
Post by Wanganui7 » Sun Jul 14, 2019 10:30 pm
Can anyone tell me what is the alloy extrusion size for the windscreen frame? Haven't found any mention of it anywhere.
davew
Post by davew » Sun Jul 14, 2019 11:11 pm
The alloy extrusion size for the windscreen frame is standard 3/4" alloy "U" channel. 19mm high, 19mm wide and the inside is 12mm. When you build the form for the windscreen, your roller need to have very smooth surface, over wise it will leave the roller surface marks into the softer alloy extrusion. 2nd if possible reinforce your rolled corners of the form with sheet metal. The "U" channel wants to collapse inward on the form and you end up destroying the corner of the form when removing the channel. Davew
Post by Wanganui7 » Mon Jul 15, 2019 5:54 pm
Much thanks, I'll give it a go.
Post by 7ish » Sun Aug 11, 2019 8:02 pm
Car is looking very nice....well done.
Post by Wanganui7 » Tue Aug 13, 2019 8:16 pm
Thanks, about to start on the windscreen next.
Post by Wanganui7 » Mon Sep 02, 2019 6:58 pm
Wanting to know where builders get the rubber seal between the window frame and scuttle from?
Post by 7ish » Tue Sep 03, 2019 10:48 am
Para rubber....
