Upgrade for 1970 lotus 7
Use this forum to openly discuss anything you would like regarding the project cars in the build diary's
* Edit post
* Delete post
* Report this post
* Information
* Reply with quote
Forum Rules. EVERYONE MUST READ BEFORE VIEWING OR POSTING
Postby KiwiBirkin » Tue Nov 10, 2009 6:10 pm
Poject Discussion Forum Rules
This is a new section of where you guys can discuss other users cars. There are just a few rules that need to be followed for this forum to stay nice, clean and easy to use:
1. ONE thread per car. Search the forum for an existing thread before starting your own, things stay tidy that way.
2. Try and stay on topic if you can.
3. Thread titles must be in this format: Username's and the car project
I have created this section so it keeps the build diarys clean and allows the builder of the car to keep us updated a bit like a BLOG so please use this section to disscuss the builders cars and we should see a much easier forum to navigate.
ady_uk
Re: Upgrade for 1970 lotus 7
Post by ady_uk » Wed Jan 04, 2012 4:42 pm
yep, that seems the case. They are now saying the car will require headrests, and the foam fitted to the roll bar is no good(which I was told would be passable,(not by Neil) is not the case).
What I can not understand is, looking on this forums finished builds, there is quite a few cars with no head rests????
Neil has be really helpful and has come up with some options, I thinking of bent tubing like on the cobras with a pad fitted, what would the thinnest dia tube I could use??? and what thickness would it need to be? I am hoping to run the tubes behind the back of the seats, where I can bolt them to the frame work. Any info would be great.
Boffy
Post by Boffy » Wed Jan 04, 2012 5:15 pm
frikin hell Ady, you really are being put through the ringer, hopefully it wont be a major to fix and you can get on the road.
Boffy
dennischristian
Post by dennischristian » Wed Jan 04, 2012 6:21 pm
The car has to comply to 2011 rules which requires head rests, I had the same issue. I took the two from the third row of setas in my Pajero drilled the cross bar that is behind the seat back and slid them in backwards. Solved a
Thoufg not the bezt looking for now.
Dennis from Nelson
Chevron
Boffy
Post by Boffy » Wed Jan 04, 2012 6:38 pm
Sudden brainstorm, I have a couple of seats that I wont need for a while, do you want to borrow them?
Boffy
Post by flewy » Wed Jan 04, 2012 8:49 pm
Interesting the headrest thing...although we have them....alot of Frasers don't including the Demo Fraser.....I can understand their need I guess.....get rear ended without one, and thats gotta hurt.
I so feel for you and wanting the car all go with this perfect weather....good luck...
ady_uk
Post by ady_uk » Sat Jan 07, 2012 5:16 pm
Thanks Boffy for the offer, fitting new seats into the car may bring more problems I think, after looking how Dennis had done his, I went a slightly different way, welded tubing to the back seat rail, drilled holes in the headrest bars, and now I have adjustable rests.
Post by KiwiBirkin » Sat Jan 07, 2012 5:24 pm
Once again Ady good luck fingers crossed it passes.
dennischristian
Post by dennischristian » Sat Jan 07, 2012 7:37 pm
Head rests look good, well done
Dennis from Nelson
Chevron
Boffy
Post by Boffy » Fri Jan 20, 2012 6:46 am
Great news Adrian, look forward to seeing you zipping around the shore.
Boffy
Post by KiwiBirkin » Fri Jan 20, 2012 9:34 am
Great news Ady now you can get it out and scare the locals ;)
