WTB: Light good brakes for cortina uprights
Any parts for sale or wanted
If you list any manufactured lotus seven parts or any other item you must own the rights to manufacture them, if you dont they will be removed.
Please add links to trademe auctions.
Please no discussion on parts for sale other than to find out if it would suit your car, please keep any negotiation on parts to PM's or emails.
Post by Talkiet » Thu Apr 18, 2019 11:09 am
Front, to replace the decent but HEAVY princess 4 pots on at the moment. Happy to buy new, just keen on suggestions or seeing if anyone had a set of suitable things lying about. Must fit under 13" wheels.
Cheers- N
20vseven
Re: WTB: Light good brakes for cortina uprights
Post by 20vseven » Thu Apr 18, 2019 6:10 pm
Hi Neil,
See Les hunter re the Outlaw ones - straight bolt on
Post by Talkiet » Thu Apr 18, 2019 6:50 pm
Well, they do look ideal don't they... I have flicked Les an email...
Thanks for the pointer...
Cheers -N
Post by nz_climber » Thu Apr 25, 2019 8:04 am
I got outlaws from Les, seem to be really good so far with no issues, much lighter than the old ones, and the vented disc was only a few grams heavier than the old solids
Post by Talkiet » Thu Apr 25, 2019 9:17 am
Thanks for the confirmation. Not sure I'll even bother getting the vented discs - might just stick with current solid rotors. Not sure I'll even get enough heat into them to justify it.
I have heard that on a really light car it's possible to have issues with the brakes not being able to get warm enough. I have tried to get in touch with Les but no luck so far. Pretty sure I'll go the Outlaw way.
Post by nz_climber » Sat Apr 27, 2019 8:58 pm
Never had a problem getting heat into my vented disc set up, pads work ok cold, but really come on after about 2 applications. Good thing about the outlaws is there is plenty of pads available (common wilwood size) and you can split them to take a spacer in the future for vented if needed.
Post by Talkiet » Sat Apr 27, 2019 11:41 pm
I'm trying to source a set now but Les is busy and hard to get hold of... Hopefully I can talk to him this week. The Outlaws do sound like the way to go. I wouldn't be opposed to new vented discs if I had to but I'd prefer to stay with the current rotors since they are the lightest option.
Post by nz_climber » Wed May 01, 2019 6:41 pm
Here is the weight comparisons
Caliper + Pads
New = 2.3kg
Old = 4.4kg
Disc's
Old (Solid) = 3.83kg
New (vented) = 3.87kg
Grippa
Post by Grippa » Mon May 27, 2019 6:18 pm
How did you go about the brake upgrade did you end up going the outlaw option ?
I’m looking into options
Post by Talkiet » Mon May 27, 2019 10:42 pm
Les reported that he can't buy the outlaws anymore - The company is too hard to deal with for him. I haven't found a bolt on option yet. The B16s from Palmside might work but I'm unsure if they can be modified to fit the half inch solid discs.
