Cortina upright - Wilwwod upgrade
Any parts for sale or wanted
If you list any manufactured lotus seven parts or any other item you must own the rights to manufacture them, if you dont they will be removed.
Please add links to trademe auctions.
Please no discussion on parts for sale other than to find out if it would suit your car, please keep any negotiation on parts to PM's or emails.
McGregor Motorsport
Post by McGregor Motorsport » Thu May 29, 2014 8:31 am
Hi guys,
If you want to upgrade your front brakes from the Cortina caliper , I have made some brackets that adapt directly to the upright.
You will need:
McGregor Motorsport adapter brackets
Wilwood calipers - part number 120-8726
you will have to make up a flexi line to suit your setup on your car.
Mark
RDSTA7
Re: Cortina upright - Wilwwod upgrade
Post by RDSTA7 » Thu Aug 25, 2016 3:17 pm
Hi Mark,
I've recently started work on a partially completed Haynes Roadster project that I purchased about 18 months ago. It has Cortina uprights and I am looking for a decent front brake setup for it. The intention will be mainly road use but some track days as well. Do you have these bracket still lying around and who what type of rotors would you recommend? Cheers.
Bruce Wilson
Post by Bruce Wilson » Thu Aug 25, 2016 5:26 pm
Try Mark at his email....
mark.srcomp@gmail.com
Bruce
2017 McGregor MACHsr7
http://kitcarnz.com/
Post by nz_climber » Fri Aug 26, 2016 3:10 pm
Or Les Hunter Brakes does outlaw calipers that bolt directly to the cortina uprights, with solid or vented disc's. Just fitted some to my car, but yet to go for a drive.
Or from the UK website's, hi spec, rally design, Burton's etc, they can be cheap at the moment. With the exchange rate.
Sent from my Nexus 5X using Tapatalk
