Brake pedal material requirments
For asking and answering questions regard the NZ Hobby Car Tech Manual.
Rules:
Only ask and answer questions about the NZ Hobby Car Tech manual any other questions not releated please ask in the other tech forums.
Post by bzrse7en » Sun Nov 06, 2011 8:16 pm
Hi Lads
In their floor mounted brake pedals, Lotus use a piece of tube as the main arm. Is there a material specification for tubular pedals?
Thanks very much
Patrick
7dreamer
Re: Brake pedal material requirments
Post by 7dreamer » Tue Nov 08, 2011 8:30 pm
Ah no you will have to apply to the lvvta for such a thing 8mm mild steel is the rule though in 7 type cars where the pedal length is unusually short and aluminium has to be %$150- %200 thicker than if you used steel
