Brake systems definitions
For asking and answering questions regard the NZ Hobby Car Tech Manual.
Rules:
Only ask and answer questions about the NZ Hobby Car Tech manual any other questions not releated please ask in the other tech forums.
boborjim
Post by boborjim » Sat Sep 26, 2015 10:10 pm
Hi all, I have been looking at the Tech manual for the requirements for a custom pedal box for my Locost. The bit I would like cleared up is the definition on Chapter 8.3.9 b
A custom pedal box assembly fitted to a low volume vehicle must
(b) designed so that a total failure of braking control cannot occur due to any individual component failure.
How far does that definition extend, I guess it the pedal snapped then it would be a total failure....
Anyway your thoughts are welcome.
Cheers.
Re: Brake systems definitions
Post by bzrse7en » Sun Sep 27, 2015 7:23 am
Consider a weld breaking, design the pedal so if this happens, it will still work.
boborjim
Post by boborjim » Sun Sep 27, 2015 2:01 pm
That's kind of what I was hoping, I have design everything in compression rather than tension so shouldn't be a problem. Cheers
