WTB: Light good brakes for cortina uprights
If you list any manufactured lotus seven parts or any other item you must own the rights to manufacture them, if you dont they will be removed.
Please add links to trademe auctions.
Please no discussion on parts for sale other than to find out if it would suit your car, please keep any negotiation on parts to PM's or emails.
Front, to replace the decent but HEAVY princess 4 pots on at the moment. Happy to buy new, just keen on suggestions or seeing if anyone had a set of suitable things lying about. Must fit under 13" wheels.
Cheers- N
Cheers- N
Re: WTB: Light good brakes for cortina uprights
Hi Neil,
See Les hunter re the Outlaw ones - straight bolt on
Well, they do look ideal don't they... I have flicked Les an email...
Thanks for the pointer...
Cheers -N
Cheers -N
- nz_climber
- Paid Member
- Contact:
I got outlaws from Les, seem to be really good so far with no issues, much lighter than the old ones, and the vented disc was only a few grams heavier than the old solids
Beams 3sge Powered Mcgregor 7 http://www.lotus7.co.nz/forum/viewtopic ... 64242d8337
Thanks for the confirmation. Not sure I'll even bother getting the vented discs - might just stick with current solid rotors. Not sure I'll even get enough heat into them to justify it.
I have heard that on a really light car it's possible to have issues with the brakes not being able to get warm enough. I have tried to get in touch with Les but no luck so far. Pretty sure I'll go the Outlaw way.
- nz_climber
- Paid Member
- Contact:
Never had a problem getting heat into my vented disc set up, pads work ok cold, but really come on after about 2 applications. Good thing about the outlaws is there is plenty of pads available (common wilwood size) and you can split them to take a spacer in the future for vented if needed.
I'm trying to source a set now but Les is busy and hard to get hold of... Hopefully I can talk to him this week. The Outlaws do sound like the way to go. I wouldn't be opposed to new vented discs if I had to but I'd prefer to stay with the current rotors since they are the lightest option.
- nz_climber
- Paid Member
- Contact:
Here is the weight comparisons
Caliper + Pads
New = 2.3kg
Old = 4.4kg
Disc's
Old (Solid) = 3.83kg
New (vented) = 3.87kg
Caliper + Pads
New = 2.3kg
Old = 4.4kg
Disc's
How did you go about the brake upgrade did you end up going the outlaw option ?
I’m looking into options
Les reported that he can't buy the outlaws anymore - The company is too hard to deal with for him. I haven't found a bolt on option yet. The B16s from Palmside might work but I'm unsure if they can be modified to fit the half inch solid discs.
