Brake Fluid?????
Re: Brake Fluid?????
Post by flewy » Thu Oct 11, 2012 2:25 pm
Just brought me some Motul RBF600, we'll see how that goes. Not cheap mind you $35 for a 500ml bottle......
Rookie
Post by Rookie » Thu Oct 11, 2012 2:48 pm
That's a bunch cheaper than not stopping at the end of a straight......
Locost 7: Powered by 1660cc of British FURY! coming to a town near you soon.
Remember: If a mechanic can do it, so can YOU!
Post by flewy » Thu Oct 11, 2012 7:22 pm
Rookie wrote:That's a bunch cheaper than not stopping at the end of a straight......
So true Rookie!!! Now with the new fluid, straight rotors and re-sealed callipers we should be stopping really well.
I had a hairy moment end of front straight last time out with an unexpected lockup at 160kph, hence the need for a clean up.....
