Duratec specs... what's the go?
Post by 7ish » Thu Feb 06, 2014 2:18 pm
SO if you wanted to build a duratec, would you go for a modeo 2.3 ltr, a mazda L3 (2.3 with vvt), or a 2.0 focus motor non vvt? Looking for around 200hp.. meant to be achievable with ITB injection and an after market ECU.
McGregor Motorsport
Re: Duratec specs... what's the go?
Post by McGregor Motorsport » Thu Feb 06, 2014 4:27 pm
I've got you thinking now have I Mr Morgan.....?
Post by 7ish » Thu Feb 06, 2014 5:24 pm
I'm always thinking...
McGregor Motorsport
Post by McGregor Motorsport » Thu Feb 06, 2014 6:07 pm
But if you're thinking what I'm thinking , then I'm thinking we are thinking the same thing?
Post by bzrse7en » Thu Feb 06, 2014 7:03 pm
There was a thread on OZ clubbies regarding this a few weeks ago.
I recall the 2.3 ranger block was the go because it didn't have a balance shaft.
Rookie
Post by Rookie » Fri Feb 07, 2014 8:23 am
Any particular reason for a Duratec?
Locost 7: Powered by 1660cc of British FURY! coming to a town near you soon.
Remember: If a mechanic can do it, so can YOU!
Post by 7ish » Fri Feb 07, 2014 8:36 am
All alloy construction, no head work needed as ports and valves good for over 200 hp, much easier to find than a honda k20a4....(and cheaper).
Post by nz_climber » Fri Feb 07, 2014 9:59 am
What are you building this time Evan?
Rookie
Post by Rookie » Fri Feb 07, 2014 6:56 pm
Looked at K24s?
