Diff for BEC
Diff for BEC
Post by 7ish » Wed Mar 30, 2016 8:03 am
http://www.trademe.co.nz/motors/car-par ... 044075.htm
3.27:1 ratio complete rear end...ideal for bec. Assembly has bolt in hubs and the new r160 diff that is 7kgs lighter than the old R160.... listing ratio is wrong...not 2.75...
Cheap as well!
Note.. I found out the hard way that these VA model R160 diffs have smaller bearings than the earlier ones, so centers cannot be changed between them. I have a 4.11 open VA R160 available if anyone wants one...
