Rfactor 2 - Wednesday 15 Feb - 8.30pm
McGregor Motorsport
Post by McGregor Motorsport » Mon Feb 13, 2012 4:41 pm
Hi Guys,
Our weekly online blat continues on Wednesday.
Niel will post the server details here.
See you online.
Mark
Re: Rfactor 2 - Wednesday 15 Feb - 8.30pm
Post by KiwiBirkin » Mon Feb 13, 2012 6:18 pm
Cool ok how about the 60s EVE F3 MS5/1 at Mills Motorpark as we know that track, you can enable this under the rFactor Series all the way to the left that allows you to use any car on any track.
Post by Talkiet » Mon Feb 13, 2012 6:46 pm
Hi guys... Server details. Not quite as straightforward
For multiplayer you need to have a specific all cars/tracks mod... The one I found that worked with the 60's cars on Mills is this
http://www.f1elites.com/showroom/click.php?id=31
Download that and install as a mod...
Wednesday 8:30pm
Cars will be the F3 on Mills...
Zero damage
25 laps
4x fuel
4x tyres
(The fuel and tyre multipliers mean we'll need a pitstop - If not, I'll adjust the multipliers/laps to ensure we do)
Just editing server now to only have the F3 cars
It'll be up in 5 mins
McGregor Motorsport
Post by McGregor Motorsport » Mon Feb 13, 2012 7:15 pm
Can't get on , keeps kicking me.
Post by Talkiet » Mon Feb 13, 2012 7:20 pm
You need to have the mid as above and choose one of the f3
Cheers. N
McGregor Motorsport
Post by McGregor Motorsport » Mon Feb 13, 2012 7:21 pm
I have done that.
Post by Talkiet » Mon Feb 13, 2012 8:35 pm
Anyone else able to try and connect? I have been able to connect using an F3 car and run laps...
I'll be in there for 5 minutes now before I need to get back to the lounge for the next show...
Post by KiwiBirkin » Mon Feb 13, 2012 9:09 pm
Ill try tommorow, tonight was my BF3 night.
Post by Talkiet » Tue Feb 14, 2012 4:08 pm
I'm out this evening but the server is up. The only cars allowed are the ones matching the filters:
"EVE_F3" and "Spark_F3" from the 1960's World Class Racing.
You Need the exact mod here titled "1960s WCR v1.1"
http://www.f1elites.com/forums/index.php?showtopic=3619
An earlier version, or any other all cars and tracks mod won't work - it has to be this precise mod downloaded and installed. The direct DL link is
ISI seems to be getting a lot of flack for this approach - it makes running online events with nonstandard car/track combos awkward - everyone always has to download a specific mod combining the car and track... There's no 'true' all cars and tracks...
Fuel is set to 7x realtime consumption, this means there WILL be a need for a pitstop.
Tyre use is set to 5x - this means you will need to change tyres too I THINK. I haven't run enough laps to see any degradation yet.
ps. I can remotely connect and check out the server later and can check emails remotely - I'd love it if someone could reply here if they are able to connect ok... I have checked it out from a second ADSL line at home and it works for me.
Post by KiwiBirkin » Tue Feb 14, 2012 6:41 pm
Installed the mod and connected fine so all good here for tommorow.
It was easy to install just drop the file into the Packages folder inside rFactor2, start up rFactor2 and click manage mods on the screen where you pick Single player or Online and it will open the rFactor2 mod manager where you should see "1960sWCR ALL Tracks by F1Elites,com" listed, then just right click on it and choose install as the option.
