OEM and aftermarket ECUs
For the discussion of ECU's and programmable ECU's
Post by bzrse7en » Sat Apr 28, 2012 8:10 pm
Here is a discussion on a 4age 20v when fitted with a piggyback ecu and some dyno tuning.
http://www.ozclubbies.com.au/index.php? ... o-results/
Some proof that, although Toyota spends a gazilion dollars on tuning, there is still some room for improvement.
Re: OEM and aftermarket ECUs
Post by KiwiBirkin » Sun Apr 29, 2012 7:55 pm
I have been watching that thread closley and put on the list of a possible upgrade at a later date.
Post by Rookie » Mon Apr 30, 2012 8:57 am
It's just like anything that has a wide parameter set, it can never do one thing well. So if you reduce this parameter set, ie only run 98, make sure you dont have dirty air and fuel filter etc, you wil be able to significantly optimise the system.
