Talking with the ECU
For the discussion of ECU's and programmable ECU's
Russell
Post by Russell » Mon Jan 11, 2010 10:08 pm
Hi
I am trying to connect with the ECU using PClink V3.40
and a laptop with a USB to Serial adapter
So far so nothing
Initially Vista looked like the problem with the USB Serial Converter being
installed on Comm 12 but the PClink only looking to Comm 8 although the system
should just check them all
But
Found a XP laptop and had everything fixed to comm 5 and the cupboard
is still bare
I get the feeling that I am missing something fundamental
Turned the key in the car after serial cable attached
also ran the car just in case it needed that
Serial cable light shows search effort from laptop
How can I check that the flat cable from the ECU is talking to the serial
box under the dash as maybe the last guy looking inside the ECU
used a hand held and did not put the plug back in etc etc
If you have a suggestion it would be a help
Next is to take the laptop and cable to the Auto Electrical guys and say
make this work
but ???
maybe I have missed a step
Cheers
Russell
Re: Talking with the ECU
Post by bzrse7en » Tue Jan 12, 2010 7:58 am
Mate, I have no idea, but you didn't say what sort of ECU it is.
Patrick
Rookie
Post by Rookie » Tue Jan 12, 2010 7:36 pm
It's an older version Link Ecu. Perhaps your version of PCLink is too new?
just an idea?
Dave
Locost 7: Powered by 1660cc of British FURY! coming to a town near you soon.
Remember: If a mechanic can do it, so can YOU!
Post by 7ish » Wed Jan 13, 2010 4:57 pm
The earlier Link ECU's needed another adapter to work with a PC. The one in my car would only communicate with a Link tuning module, not a PC.... What is the model of your Link??
